RCU Forums - View Single Post - Set Up Help (PLEASE HELP)
Old 01-27-2010 | 04:38 PM
flying16150
Default RE: Set Up Help (PLEASE HELP)
Im a bit confused about two switches and the 6.6 lifePo', I have one of those acuecycle elite chargers from hobbyco Im guessing that will charge the LifePo's, still a bit confussed about the set up your talking about , would it be to much to ask for a picture or Diagram or if you know where I can download it from the net , even better I have two rx's both 2.4 but havent a clue how to get them both in the set up , but will do it if showed or explained to me , like I said I want no corners cut on this plane as far as set up or anything else for that matter , are the LifePo's safe and lighter than the normal packs. As far as the servos go I will upgrade them if told what I need , I dont have a problem with that. The overall weight of the plane is 26 lbs , so Im thinking about changeing the engine from the 80cc to the DLE 111 I have new in the box , so that might take care of the weight problem right there. Im not real sure whats underneath the covering but fixing to find out in about two weeks when I start striping the covering off for a recover. But like I said I do not want to skimp on this plane , I fly better when I know It isall right.
ORIGINAL: nmking09
Awesome scheme.
Personally, I run two 7.4V 2100mah Lipos on my 33%. I don't run a regulator. The 170's and 160's will handle the extra voltage, but I don't know about the 9303's. I have 170's on the ele's, 160's on everything else. When you run that voltage you need to be dang sure you don't have any binding.
A better recommendation would be 6.6V LifePo's Two 3200 packs should do it. You will need a charger for these and hobbyking.com has one that works quite well. I think Tower has some new 3200's out that would work great.
I also have been running two RX's and two switches, (right, Left) with rudder on right and throttle on left. Do not split ganged servos between receivers.
Don't think power expanders and regulators are worth it, just seems like something else that can fail.
I think that's all I have for now. Good Luck!
