RCU Forums - View Single Post - Kingtech turbine
Old 01-28-2010 | 08:56 AM
  #45
lov2flyrc's Avatar
lov2flyrc
My Feedback: (24)
Default RE: Kingtech turbine
ORIGINAL: mdeseve
i HAVE A QUESTION FOR KINGTECH OWNER, WHEN YOU START IT DIRECTLY ON PROPANE WHAT IS YOUR SET UP, DO YOU USE A RESTRICTOR, DID YOU CHANGE THE GAS SETTING % .
THANKS
MIKE
Mike,
Is the delivery valve your using regulated or pass through? No restrictor needed, gas setting will control gas flow. Let me know what kind of valve and I can give you a good starting range for gas and glow settings.
