RE: crockpot method
Why would you not put the carb in there? All the pictures I've seen show the carb in the solution with all the rest of the parts. I understand if it's got a plastic throttle arm I would probably want to take that off but shouldn't the metal carb body be ok? Otherwise, how would you get that clean to match the rest of the engine?
