RCU Forums - View Single Post - My Car Is......
Old 01-28-2010 | 12:39 PM
leadfootdriver's Avatar
leadfootdriver
Default RE: My Car Is......
I have more experience with airplanes in this hobby because ive only been driving cars for about 7 months now i just switched over and im very mechanically inclined which helps but this car is very easy to learn you just have to stick with it no matter what it throws at you just make sure you keep your manual it will become your bestfriend after you have to do some work on the car like the more stuff you have to fix/replace you will learn how to take it apart and put it back together its not to hard just make sure you dont accidentally put a screw back in in the wrong spot ill tell you what ive learned so far about this car theres only four types of screws droop screws are what adjust your ride height their not used often set screws the same i think theres only one or two one the entire chasis then theres the screws that go into the plastic and the threads on those are spaced kind of far apart so you can identify them real easy then theres the machined screws and their the type that have metal to metal contact only and thier threads are really close together and theres alot of threads on each screw for that type then the screws that go into the plastic if you stick one of those in where a machined screw goes your F-ed and so is the part you tried to put the screw in so always check what screw your using and where your putting it
if any of this is confusing tell me and ill explain in greater detail
