ORIGINAL: Ed
johndou - '' By the way, if you're buying a used copy of RealFlight make sure that the previous owner has un-registered it. You won't be able to register the software unless it's un-registered by the previous owner. ''
Is registering it absolutely essential in order to use it ?
Thanks guys.
Ed
Why wouldn't you want a "registered" copy? I believe that you can use the sim without registering it. But, you're using what is on the disc only! As I understand it you have no access to the upgrades.
You need to be aware that KnifeEdge has made improvements to G3 since it's release. G3 had a number of bugs that have been eliminated through upgrades. The program (G3) that was released on disc is not the same G3/G3.5 that people talk about now. It is quite a different product.
