RCU Forums - View Single Post - Volcano S30 Transmission Woes
Old 01-29-2010 | 01:56 AM
Merc250
Default RE: Volcano S30 Transmission Woes
OK! Finally, I got down to the problem that was plaguing my trans. I actually has stripped a gear inside there. It wasn't a spur gear, but luckily, was the same size as the spur. I swapped the stripped one out for the aluminum spur, and all is well!
The reason the trans worked when I pushed the shaft forward is that I was engaging what was left of the gear into the other gears. The gear was totally shot except for about 5% of its surface on all teeth.
Yes, my trans is the one that is pictured earlier in the thread.
Merc
