RE: Sig Acromaster
In my experience, too much flap deflection (more than 15 degrees) has the opposite effect for which it was intended, actually adversely affecting the lift component of the wing and causing a nose down pitching moment.
The 90 degrees elevator travel mentioned would surely act much more effectively as a speed break rather than an AOA influence. I use about about 25 degrees as Jim does.
