ORIGINAL: hotrod34a
Joe,
You might still want to consider mounting full size servos in the rear as you could run into a CG issue since you are going for the larger motor and batteries. You might want to read my earlier post as to what I found out when building mine about this issue. Unless you are planning on removing your stabs.... Just a thought.....
Larry....
That will be plan B. It took a while but I got one of the Atx mini's mounted in the stab, and hopefully with the lighter motor, lighter gear, and everything shoved as far back as possible the balance will work out. I'll try a heavier (more capacity) set of Rx batteries before I go with the heavier servos.
