RE: Losi Desert Truck replacement servo???
Just an update, I ended up getting a Hitec HS-5055MG and LOSB1226 servo saver. The splines on the Hitec servo are smaller than the stock servos. The servo saver kit includes the servo saver and mounts. The one hole on the Hitec servo needs to be elongated and both ends needed to be shaved a little bit to fit into the chassis. It snowed today so I couldn't try iy out yet. But bench testing looked good.
