RE: Kingtech turbine
<span lang="EN-GB" style="FONT-FAMILY: Arial; FONT-SIZE: 9pt; mso-fareast-font-family: SimSun; mso-ansi-language: EN-GB; mso-fareast-language: ZH-CN; mso-bidi-language: AR-SA">Hello. Thanks fore response. Turbine is brand new. Only 4 successful starts until now and a total of 6min run time. No change on any parameter. A steady stream of fuel comes out the end of the fuel line when operated manually. The stream starts slow and build up to full in 5sek or so. When operated manually everything seams to work ok. Don’t know about the start engine sins I don’t have any to compare with. Rpm on shut down I don’t know but I will have a test run today and video the run. <span lang="EN-GB" style="FONT-FAMILY: Arial; FONT-SIZE: 9pt; mso-ansi-language: EN-GB">If you can sent me a copy of yours setting I can compare with mine. Thanks. </span><span lang="EN-GB" style="mso-ansi-language: EN-GB">
</p></span></span>
