RCU Forums - View Single Post - Angel S EVO Build Thread
Old 01-31-2010 | 08:38 AM
  #589
BaldEagel's Avatar
BaldEagel
Default RE: Angel S EVO Build Thread
One of the easiest ways to seal the hinge line is with a small bead of silicon mastic on the underside of the surface, I only seal the elevator and the ailerons as the rudder always seems to be effective wheather sealed or not.
I put the latch on the canopy with the handle sticking up through the perspex and bent over at right angles, this allows it to be used as a means of getting the canopy off, I also took out one of the magnets at the back as with the latch it is superfluous. Post 149 on page 6 shows the catch.
Mike
