RCU Forums - View Single Post - Nitro engine not starting
Old 01-31-2010 | 10:57 AM
DarZeelon's Avatar
DarZeelon
Default RE: Nitro engine not starting
ORIGINAL: Lowflyer281
...I'm trying to start my .90 size nitro 3D plane.
LF,
Maybe its because of the name you call it...[>:]
It is not a nitro engine. It's a glow engine, which uses methanol as its main fuel component...
It will easily run if there isn't even a drop of nitromethane in the fuel. But if there's not enough methanol, you can just forget it...
I couldn't care less what all your buddies call it; is is a glow engine and being a largish .90 size, a lot of nitro will just make it run worse.
Cold weather does not make starting very easy.
Make sure the glow-plug glows bright orange and that there is a little fuel in the cylinder.... It should at least pop, as you crank it over.
