RCU Forums - View Single Post - BME 58 Extreme
Old 01-31-2010 | 01:00 PM
  #144
RTK's Avatar
RTK
Default RE: BME 58 Extreme
How's the compression??
The 58/116 like props that let them spin up, shoot for at least mid 6's on the ground for the 116 and around 7 for the 58.
If you do not have adequate air flow and especially good extraction it is not good to run a new engine on the ground for extended periods, you have learned this so now just put the plane in the air and have fun. When the prop un-loads you might be surprised. BMEs like/need to spin a little more than some others for peak torque
