RE: Dubai - RC Events
Hey Tommy,
Tried you last night, but you were on the yapper......engaged...
I believe that space limitations could be the only thing to throw a stick in the works. I will keep you upated and will try your number again this evening. In the interim, thanks for the info, will feed it back to the peeps...
If the space is too small, would it be worthwhile in your opinion? I know that as per the design that they have, the max track width that can be done is 3.5m and according to rules and regs online...it should be 4m. right?
