G'day ALL... I have a new 12X on 2.4 ghz. I'm trying to program it in a Comp-Arf Euro. I have the wing type selected as Delta. The right ail is in ail channel, the left goes to elev. [At this point the manual says the plug the right control to aileron channel two and plug the the right control into elevator] I guess they mean the LEFT control. Okay, so that works fine. Now. I can adjust the travel of the control for either elev or ail but if I alter aileron travel, it also alters elevator travel. The Euro has about 15mm up and down for ail, but require as much as 45 mm up for elev. Does anyone on line know what the blazes I should be doing? Surely I can have 45 mm up on elev, but only 15mm up on left bank??? Please help. Ancient Cliff
