RE: Taildragger Landing Technique
Nose heavy will do it..You need more airspeed with a nose heavy airplane. If you try to hold the nose up it will stall. You can keep the throttle higher or come in at a steeper angle. But most of all - make sure the plane is balanced.-BW
