RE: Taildragger Landing Technique
If you need tail weight, it is pretty easy to remove the covering from one of the lightening holes toward the rear of the fuselage. This will allow you access to glue in something to strap your receiver battery to. You may have to use an extension on the battery wires depending on how far back you go. Once you have it all secure just put a covering patch over the hole and nobody will ever know.
