ORIGINAL: 3DDino
in that case single is not that bad after all
how do you determine to use twin or single of the same size for 3d flying
thx
This is the only twin engine under $500 and can swing 24-8 prop up to 7K with stock muffler and engine weight only 3.26lb with plug !!!. People know the advantage of twin engine compare with single. Smooth without vibration and we made it still light weight just like single cylinder engine is what was posted. Now a 24X8 prop turning 7000 RPM sure should hover something!!!! Capt,n
