RCU Forums - View Single Post - What would you guys do?
Old 02-01-2010 | 07:35 PM
CGRetired's Avatar
CGRetired
Default RE: What would you guys do?
I looked over the airframe tonite. The darned rudder is bent halfway (the top half goes left while the bottom half goes right) so, somehow, somewhere, I broke the rudder. Soooo... sloppy storage, I imagine, but, being a human, I guess that sort of thing happens. So, fix the rudder is right at the top of the list. Jeech.. now I have to pick up some CA. And, that means an hour drive to the LHS. So, before I do that, I'll need more fodder to spend my hard earned money on.
Ok. In addition to what was already recommended.. and as I said, fix the rudder is on the top of the list. Then remove the tank, and the engine and check servo leads at the Rx. Cycle batteries (as I said, two). I already checked out hinges and clevis connections, all are fine. And, there are no critters making a home in the airframe.. [sm=thumbs_up.gif]
Next.. well, keep the recommendations coming. I'm certiain that more RC'ers are looking at this and can gain some insight as to what to do in this situation.
CGr.
