RE: Shrike flight report
The wing center section is not at 0. It is actually at 3.5 I believe. I have been using my Robart incidence meter a lot in my build and it is a life saver! So Leo, do you think 0 degrees on the tail would be better? It doesn't look like you have to use much trim. Also are your trim tabs separate pieces, or have you just cut the edges and made it look like it? They look great!
