RE: New CDI - opensource project JMJ and Bigboat
@gr8flyer55, thanks to explain the output of the new board.
I'll change today some layouts so everything can be placed on the pcb without braking the parts.
With the pcb you have nao, nive pcb you have make, the 5V regulator didn't fit on the board.
The 220uF capacitor can have a value of 47uF/16V and the 47uF/16V can be replaced by a 10uF/16V.
On the TCI-powerboard, D1 must be 1N5406 for a small sparkcoil and a (10A diode) if you use a big sparkcoil.
TIP162 must be replaced and the 220nF capacitor will be placed to the bottom of the pcb.
