RCU Forums - View Single Post - New CDI - opensource project JMJ and Bigboat
Old 02-02-2010 | 04:01 AM
  #600
kermet
Default RE: New CDI - opensource project JMJ and Bigboat
John, Rob, my hand drill only does 1200 rpm and i doubt i can pull start it any faster than this.......
at 1200 rpm my timing is 25 degrees, but i put 10 degrees into the exel sheet
So this is because the programe can not read below this figure under that rpm, i understand this
Hiust tested with the timing light and i see the light goes out after a few hard pulls, like it stops triggering
the SCR,
but with the plug out it is fine up to 1200 rpm
i must have a trigger issue with my two boards
brett
