ESM P47 Build
Hi
I've run into a small problem building an ESM P47 that I need some help with. The vertical stab is composite - very thin and hollow. The rudder is balsa. The hinges are Robart hinge points, 1/8 inch. The trailing edge of the stab is about maybe 3/16" thick. I just don't think that there's enough meat there to hold the hinges.
I've read several posts about how people have installed hinge points, but I didn't really find a situation like this.
I'm guessing all the ESM models are similar construction and maybe this is a non-issue, but it sure seems like a weak point. I've thought about trying one of the expanding glues, but the sides of the stab are so thin I'm afraid they might bulge.
Any suggestions?
Regards
Michael
