RE: Critical Voltage for 2.4ghz Rcvr?
If your battery stays above 3.5v to 4.0v(depending on brand) the receiver will operate. If your system is not adequately charged or uses a battery that under load will fall into this range, there will be loss of reception until the battery voltage returns to above that level. Sloppy battery management will bite you whether using 72Mhz or 2.4Ghz.
