RCU Forums - View Single Post - Missing Parts On A 50cc Biplane
Old 02-02-2010 | 02:24 PM
skypainter
Default RE: Missing Parts On A 50cc Biplane
Had to knock out the 5 blind nuts on main landing gear, replace with 10-32 nuts, I used the supplied bolts , but woundn't recommend, the thread is off slighlty, Also I used blind nuts for the wing brackets, should work better than the supplied lock nuts, ( 4-40 nuts with socket head bolts)
While working on fusalage the cross brace at the rear by the servo mounts for the elevators, that cross bracket just fell out, ( What the ????) SO REGLUE AS MUCH AS YOU CAN GUYS.
