ORIGINAL: cavandish
Heeeeeeelp
I have just purchased a new gaspar fadec (from xicon) for my wren 54mk11, software is version 5.63 could somone please give me some parameters to start with for the following
These are my Mk2 wren settings
accel delay 27
decc delay 24
stability delay 55
pump limit ??
pump start point Auto +1
pump start ramp 004
starter power at ignition 90
ignition max rpm - if you mean Rpm starter off in ignition phase 5K
ignition min rpm - if you mean minimum safe rpm for fuel ramp 4K
pre heat time 6
starter power at preheat - If you mean at beginning of fuel ramp 90
rpm 100%starter power 20K
rpm off starter 30K
rpm to reconect starter 24K
Don't have a pump limit setting must be on later version.
My starter power setting at ignition on my JJ1400 is 50 so maybe you could try lowering it as well.
