RE: ESM P47 Build
For you who have built this, how did you mount the cowl? It looks like from the manual you screw the cowl on from inside the fuse. While it's possible for the top and two side screws, I don't see a way to do that with the bottom screw unless you cut an access hole in the fuse in the belly pan area.
The only other way I can see is to access through the front of the cowl. Easy with no engine, but prolly not possible with an engine mounted in there.
Regards
Michael
