RE: Needle Valve Initial Settings?
OK, thanks. I started with 1 turn out and around 1/3 throttle or a little more. It started about 1 1/2 or 2 turns out but it seems to burn just the fuelI primed it with, maybe a little more. Adjusting it seemed to make little difference.
I will pick up some more glow plugs, I will need them anyway for the other one.
I will also attempt to determine if fuel is flowing to the carb or not.
