RE: change Focus Sport to Electric
Nixed,
Thank you for the information. I ran the numbers and you are right, with the prop and batteries you are using the motor seems to be within its current limits. You are running at about 1400 watts which is a little more than it is meant for. I guess that the AXI 4130/16 is the little engine that could. Puts the motor in a new perspective, since I thought about it as a motor for a 6-7lb aerobatic plane, not a 9-10 lb aerobatic plane.
Good luck,
Teo
