RCU Forums - View Single Post - Kingtech turbine
Old 02-04-2010 | 05:36 PM
  #92
lov2flyrc's Avatar
lov2flyrc
My Feedback: (24)
Default RE: Kingtech turbine
ORIGINAL: JET FX
Hmmm might have something to do with your location ''Florida'' you are close to the Burmuda triangle afterall.... How many pumps did you test??
We had one pump failure almost immediately on the stand when first testing the Kingtech engines. We then took another pump and let it run at 2.1V for a solid 8 hrs (and noted some substantial fod in the fluid), then put it back on the stand and it had delivery issues.
We then ran a second which showed the same signs after around 10hrs.
I recently tested the latest version using the same method for over 30hrs, pump performed better than when pulled out of the box with very little FOD in the fluid. Seems they have fixed the problems with wear....
This is why we packaged the Kingtech with Flightworks pumps. The new Kingtech valves have proven very reliable as well.
Todd
