RCU Forums - View Single Post - ARF's gliders
Thread: ARF's gliders
Old 11-24-2002 | 05:59 PM
HGU 34
Default ARF's gliders
I have an Aspire 2M glider that flys well. It is a little on the heavy side and could be improved with some weight reduction in the solid tail surfaces. It is not an exceptionally lightweight sailplane but will achieve a much lower flying weight than stated on the box if you use mini servos and/or move the servos, Rx and battery as far forward as possible and then use longer pushrods. The included pushrods are very poor and overly heavy anyway so replacing them is no big deal.
The covering also has some sags and wrinkles in it that need to be removed with a heat gun or iron but I suspect this is common with ARF's. Some attentiuon is also required to make sure no warps in the wing result when you tighten up the covering and this is not mentioned in the instructions. There are also a couple of other minor build issues that are outlined in the reviews section on this site.
But when built it is stable on the hi-start and flys well. It is not a floater exactly but still does well in light thermal activity. The Aspire also has reasonable wind penetration and with it's rather heavy tail feathers would stand up very well to a power pod. The current plan is to attach a Tee Dee .049 on a power pod for self launching out of our rather large (but too small for a full size high start) yard. It should be significantly lighter than the EP version of the Aspire.
