RE: Real Flight 3.5 and Futaba 9CAP
I assume that the 9C is transmitting when the Switch is on, even if the Trainer Cord or Flight Sim Adapter Cable is connected to the Tx. With the Antenna Down, The RF Module could become damaged, from Heat Buildup, unless it was Removed while using the 9C with the Flight Sim. Do you find this to be the case?
