RCU Forums - View Single Post - First Flight.
Old 02-06-2010 | 12:09 PM
jimmyjames213's Avatar
jimmyjames213
Default RE: First Flight.
ORIGINAL: nrad2000
I don't know how slow the escapade can go. I asked my buddy and he said it should float down. Like the simulator - the escapade went where I pointed it. On the simulator I pull back on the throttle and the plane slows down really fast. The escapade just keeps on darting forward. Next time (I don't know if it is adviseable) I'll take it up high and see how slow it can go before the wing stalls.
Engine question: If I see a small pooling of oil/fuel on the bottom of the crankcase (where the back plate meets the crankcase) - is there a leak? The magnum xls 46 (the one I have) does not have a gasket.
What do you guys think about an OS 46LA?
your magnum is FINE dont worry about it. like i said wait a gallon before you judge it, its a decent engine that is way more powerful than a os 46 la, and is just as powerful as a ax46
most engines do leak a bit, tighten the bolts. you should do that from the factory on all engines and again after 10 or so tanks
it isnt unusual for ANY engine to die on you during the first 20 tanks, it just needs a little breakin time and some fine tuneing.
as for your landing speed, try a 11x5 prop, your engine wont deadstick as often from overheating and your plane will slow down much faster
