RCU Forums - View Single Post - crockpot method
Old 02-06-2010 | 03:25 PM
albsurfer
Default RE: crockpot method
ORIGINAL: NM2K
ORIGINAL: albsurfer
ORIGINAL: cymaz
Try this product or the equivilent in the U.S.....
http://www.mysupermarket.co.uk/tesco...ray_375ml.html
I have used it with good results, not toxic and can be flushed off the engine with warm water straight down the sink
CYMAZ has the right idea. In a recent mag article ''DAWN POWER DISSOLVER'' was mentioned to use. It got my 55AX VERY clean without a lot of muss & mess. Use it in an open area, preferably OUTSIDE because it smells like a low power OVEN CLEANER. I gave it one coat, let it sit for 20 minutes, brushed it with a toothbrush, rinsed with water. I did another coat like that and a lot came off. On the 3rd treatment, I used med-hot water to rinse it and gave it one last scrub with a toothbrush and WOW, almost everything came off of the engine, including in the fins! I think the warmer water activated the cleaning ability of the cleaner more. GREAT STUFF.
Anyone who has had a coolant leak or a heater go bad in their car knows how bad, and caustic, using anti-freeze can be.
In Harry Higley's book ''All About Engines'', he cleans out the carb with a toothbrush, packs paper towel into the carb intake and the exhaust. He then recommends BRUSHING on carb cleaner, give it a short time to act, then use an acid brush to clean off the goop. Rinse the engine with water inbetween applications and give it a final rinse when you are done.
The problem is, Harry's book was written some time ago, long before the introduction of the Dawn/Fairy pot and pan cleaners. I'm not saying that his advice will cause harm. Not at all. I'm saying that there are better methods available today.
I use Dawn Power Dissolver (?) (dang memory) for light jobs. But if you have a really crusty coated engine, I can't see spending an hour or two of knuckle busting scraping and brushing when an over night soak in a warm crockpot of Prestone 100% antifreeze will do an even better job.
Ed Cregger
Yes, Harry's book is a 1992 book with NO revision. I can see the carb cleaner causing a problem with the carb O-Ring. I can see using the crockpot method if your engine is really bad off with a few years' worth of crud and castor. If you are doing some reasonable periodic cleaning, Dawn is a great way to go. My 55AX was 1-1/2 years old upon cleaning. It wasn't as bad as a 5yo engine that's been flown a lot. I have one of those to clean still. [sm=tongue_smile.gif]
