RCU Forums - View Single Post - Engine For Vector Flight Edge
Old 07-11-2003 | 09:34 PM
WhtBronco's Avatar
WhtBronco
Default Engine For Vector Flight Edge
I am waiting until the boss okays the purchase of the VF Edge to order it but I plan on using a Saito 100 in it. I always go with atleast the manufacturers high end of engine range, frequently a bit higher than that.
My only concern is servos. I will likely go with standard JR 537's since VF recommends standards and then upgrade if need be.
Good luck with it. When you get it completed I'd like to hear how the the assembly went, what engine you ended up using and it's flight performance.
