RCU Forums - View Single Post - Kits?
Thread: Kits?
Old 02-06-2010 | 07:36 PM
Gray Beard
My Feedback: (-1)
Default RE: Kits?
Depends on the plane, Fiberglass specialities has cowls and canopy's for a lot of the plans and old kits, landing gear and wheel pants too. Sometimes I just make my own cowl out of wood. If the kit has one then you can make your own plug. I have also made cowls from foam and used it as a plug and glassed it myself. A trick is to look at all the different ARFs and find one that is about the same size and type you are building and just buy what you need from them, ARF makers sell parts if you didn't know. This is a Sukhoi 29 I built from plans. It was designed for a 1.20 four stroke, I made some changes and installed a 40cc Brison gasser. The cowl was on the plans or how to make your own, I could have bought a glass cowl but I designed this one so the top opened and I could get to the engine. Your building the plane, do what ever you like to it! The canopy was bought at Fiberglass Specialities and the landing gear I bought from Wild Hare ARFs. Later on I made up some spats for the wheels. Let your creative juices flow, it's your plane and your rules. Let the thinking process flow. Go ahead, draw outside the lines.
ID:	1373251   Click image for larger version
