Guys.....Smart-Fly question.....help me understand!!!
So fellas.....in my last 5 jets I've used the Spektrum 6010 regulators straight to a Spektrum AR9100 receiver simply for convenience. I have 2 brand new 2000 mah Common Sense 2s Lipos that I want to use on my GJC F-15 and I just cant grasp the set-up. How exactly does it work if I want to use a Smart-Fly Turbo Regulator? Battery with Deans connections to the regulator, then regulator to the receiver? No switch needed? The power is "on" when you plug the batteries into the regulator or is there a switch needed at some point? Just not getting it.....when I used the AR6010 regulators they connected straight to the receiver and they had independent switched for each reg.
Thanks in advance
Spence
