RE: New CDI - opensource project JMJ and Bigboat
Wat have to be changed.
1 - low rpm - now the timing start at 1800rpm.
2 - place BTDC - now it's fixet at 40 BTDC.
3 - 2x ocsilator output - to feed the HV-board.
4 - flashligt output - flashlight isn't posible in TCI-mode.
5 - variable delay - to use the timerboard with 45/55% delay.
6 - more timetables - switching between more timetables.
7 - only table loading - not compile the hole code only the tables.
