RE: Giant Scale Twins F7F Tigercat
Just got the right side of the center section sheeted.
But before I started that, I first cleaned up the left half by trimming of the excess sheeting that overhangs the flap cutouts. Sharp hobby knife and straight edge and done.
Next, I started to transfer some of the locations from under the sheeting to the top of the sheeting. I marked all the spars (specially on the bottom if I choose to tie in the landing gear mounts to the spars), center section plywood joiners, and servo wire tunnels. I also marked where the holes need to be drilled to accept the wing joiner set-screws. I basically marked everything, because you never know when you're going to need that info.
