RE: Pick a kit!
From what I have read they are tough to get airborn off the water. Some guys have had luck with the added fuse chines to block the water spray from the prop. Some guys hand launch and land on the water. Also noted was it is good to waterprof the pushrod exits so the radio stays dry. I can give you the motor/battery specs I used if you want to go electric.
