RCU Forums - View Single Post - Crashed my first flight
Old 02-07-2010 | 09:19 PM
Instructor's Avatar
Instructor
My Feedback: (16)
Default RE: Crashed my first flight
You said the plane will not move until you reach 50% throttle. Make sure the propeller is on the right way. Make sure the flat side is facing the motor, not the nut that holds it on. I think you need to balance it. Pick up the plane with your left & right fore finger under the wing along side of the body where the wing sits on top of the fuse. When you have your fingers located at the 25% of the wing, measured from the leading edge to the trailing edge. The nose should drop 15ยบ. If it doesn't drop at least 15% below level, add some weight to the nose, under the motor until it does. Let me know how this works out.....
Larry
