RE: Fuelproofing firewall
Ken, you are exactly correct using heat to thin epoxy.
I've never had a problem using alcohol so the heat solution never came to me. The gooey mess can result from using household alcohol instead of denatured due to the water content.
Good luck with your project either way you choose.
Jeff
