RCU Forums - View Single Post - JR Radio Issue - Elevators on two different channels
Old 02-07-2010 | 11:47 PM
SinCityJets
Default JR Radio Issue - Elevators on two different channels
So I was re-doing a radio install on a King Cat today and had the elevators on two separate channels using JR's dual elevator function. The channels used were Channel 3 and 10. When I moved the elevators, they moved at different rates. It's almost like the signal was being processed at different speeds.
When I put them both on the same channel (using a Smart-Fly EQ-10) they move at exactly the same rate.
So, since the servos speed is not the problem, it is either a problem in the EQ-10, although I doubt it since it just transfers the signal from the receiver, or it is a difference in the receiver.
Any help or insight appreciated.
Chad
