ORIGINAL: Harley Condra
Chad,
Here's how you can do it.
In code 17, inhibit Aux 2, Aux 5, Aux 6 and Aux 7.
Then, in code 22 set the wing type to ''Normal'', then in ''Mate'', enter AUX2 in AIL, enter AUX5 in ELEV, enter AUX6 in FLAP, enter AUX7 in RUDD.
When you select code 11 (reversing), you will see that the channel names have been altered to indicate the new assignments. Plug the servos in as indicated.
Ch. 1 Throttle
Ch. 2 RAIL
CH 3. RELE
Ch 4. RRUD
CH 5. GEAR
Ch 6. LFLP
Ch.7 AUX2...not used
Ch 8. AUX3....use for brakes
Ch 9. RFLP
Ch 10 LRUD
Ch.11 LAIL
Ch 12. LELE
Hope this helps...
Thanks Harley. That is what I did, except I used channel 10 for the mate.
