RCU Forums - View Single Post - DLE30!
Thread: DLE30!
Old 02-08-2010 | 10:11 AM
  #1883
captinjohn
Default RE: NEW DLE30!
ORIGINAL: ol_seabee
Looks like I won't be using either of the 2 different sized Dubro filters I bought
Sheese, I want some filtered FLOW AREA
I don't trust they'd let enough gas through especially with a few particles added
Why make a larger frame filter and have such a small filter pass area?
not metal screens on either
I liked the great planes filter for glow better and it is small for the 30cc gas application imo
I'll look elsewhere, I can always step up tubing size to accomodate a lawn equipment filter
My big 3-Ws both have much larger filters and no probs
I would sugest test the flows of the fuel filters you have. Think about this....most filters you find in chainsaws ect can pass fuel very good when in good shape. If you was talking glow fuel, some walbro type carbs will not pass glow fuel fast enough. With gas you should have no broblems if you filter the fuel going into your main fuel container & use a clunk type of filter in your airplane fuel tank. Use some common easy ways to test the filters you do have, and replace if needed. All will be well then. Capt,n
