RE: HELP!!! Engine Mount for Saito 150?
I tap the holes and use the tap in a V/S drill
The plastic holds onto the threads. even a sheet metal screw will not vibrate out.
Try a sheet metal screw in wood and it will back out faster than you can shut the engine off
