RCU Forums - View Single Post - Crashed my first flight
Old 02-08-2010 | 04:47 PM
  #42
FLYBOY's Avatar
FLYBOY
Default RE: Crashed my first flight
ORIGINAL: Villa
Hi chasni
With your complete lack of experience and no possibility of any help, I would consider hand launching the plane with the motor OFF. It would be nice if the motor battery can be removed to reduce weight, but still allow the receiver and servos to work. The CG would have to remain the same. I would take the propeller off but add something in its place that weighed about the same. You can land the plane safely if it is properly balanced and trimmed and you do very little with the controls. I have seen gliders launched this way prior to a full launch, to check things out. Since the plane will be going very slow you may learn something without doing more damage to your plane. Are you certain that the control surfaces are moving in the correct direction? It is very common to have them moving wrong. I will let others help you with this because I am not familiar with your plane or radio. There are others here from your country if you want to do some searching.
Don't do this, it is a sure way to trash the plane quick!
Get a sim and learn to control it if you can't find help. It will save you a ton of frustration and money.
