RE: JR Radio Issue - Elevators on two different channels
Use the channels as they are labeled on the application manual, not all channels work the same in certain conditions, and with the 1221, that's like a power expander and can take up to 50Amps, which saves weight and wiring, use the servos direct to the receiver.
I had the same problem a year ago, and it worked when I plugged the servos as the mentioned manual suggested.
Regards
