RCU Forums - View Single Post - New CDI - opensource project JMJ and Bigboat
Old 02-08-2010 | 06:59 PM
  #721
Bigboat
Default RE: New CDI - opensource project JMJ and Bigboat
There must be 256 numbers in the table.
The numbers are differend if you don't make the same table.
See wat happens if you make the hole curve 15 degrees or 30 degrees.
The curve into the curvegenerator is the most common.
