RCU Forums - View Single Post - New Hitec Aurora 9-Channel 2.4Ghz Radio System
Old 02-08-2010 | 11:11 PM
  #944
ed42d-RCU
My Feedback: (13)
Default RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System
I had a similar problem. When I first got the radio, I tried charging via the wallwart for over 12 hours. It wouldn't charge the stock pack over 7.0 v. I called Hitec and they were suppose to send me a new wallwart...but I haven't seen it.
I pulled the battery and charged it using my Triton. I had a charge cord with a Dean's mini plug. This time using .4 amps, it charged to about 8.5v. The problem was after about a day, the transmitter low voltage would start beeping.
I finally slow charged the battery using .1 amp for about 20 hours. That did the trick. Now my battery holds it charge for over a week and it's still 7.6 v.
It sounds like your battery charger is working. Maybe you should try charging it for 24 hours or hang on and someone will have a better solution.
Good luck!.
